# Page Not Found
The URL `user-guides/autopilot/the-cube/setup/firmware/installing-secure-firmware` does not exist. This page may have been moved, renamed, or deleted.
## Suggested Pages
You may be looking for one of the following:
- [Installing Secure Firmware](https://docs.cubepilot.org/autopilot/the-cube/setup/firmware/installing-secure-firmware.md)
- [Installing ArduPilot](https://docs.cubepilot.org/autopilot/the-cube/setup/firmware/installing-ardupilot.md)
- [Firmware Recovery](https://docs.cubepilot.org/autopilot/the-cube/setup/firmware/firmware-recovery.md)
- [Firmware](https://docs.cubepilot.org/autopilot/the-cube/setup/firmware.md)
- [Installing a custom app](https://docs.cubepilot.org/herelink/herelink-user-guides/installing-a-custom-app.md)
## How to find the correct page
If the exact page cannot be found, you can still retrieve the information using the documentation query interface.
### Option 1 — Ask a question (recommended)
Perform an HTTP GET request on the following URL with the `ask` and `goal` query parameters:
GET https://docs.cubepilot.org/autopilot/the-cube/setup/firmware/installing-secure-firmware.md?ask=<question>&goal=<user_goal>
`goal` is what the user is ultimately trying to achieve, the reason they need the answer. Sharing it helps GitBook give you a better, more relevant answer. A goal is most helpful when it describes the outcome the user wants rather than restating the question. For example, with `ask=how do I create an API token`, a goal like `automate deployments from our CI pipeline` lets GitBook tailor the answer to that use case.
### Option 2 — Browse the documentation index
Full index: https://docs.cubepilot.org/sitemap.md
Use this to discover valid page paths or navigate the documentation structure.
### Option 3 — Retrieve the full documentation corpus
Full export: https://docs.cubepilot.org/llms-full.txt
Use this to access all content at once and perform your own parsing or retrieval. It will be more expensive.
## Tips for requesting documentation
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/autopilot/the-cube/setup/firmware/installing-secure-firmware.md`).
You may also use `Accept: text/markdown` header for content negotiation.
